Forward tine v reverse tine tiller
   / Forward tine v reverse tine tiller #1
Atypical_decorum
NYC
Ultra-Wide B7500 & looking for a 100hp
I can get a 104" forward tiller set to cover both my tracks.
Or
I can get an 84" reverse tine tiller set to cover one track.
Which is better? Ground is hard, shale filled, clay....On an angle.
   / Forward tine v reverse tine tiller #2
Do you want a forward or reverse rotating tiller? They are different animals. It's inconsequential if it covers your tracks to be honest. I never understood everyone's obsession with covering their tracks. Why do you have your tractor stance so wide? Are you running 2 row - 4 foot/row equipment with your tractor at 8'?
   / Forward tine v reverse tine tiller #3
How many acres and how steep is the hill ? Pictures? If it was me I’d pull tires in to under 84” and go with the 84 tiller.
I'm not sure what I NEED. What I want doesn't matter...
Wide because it's steep. The last owners rolled their tractor, I want to lessen that chance.
The ground is anywhere from 15 degrees to about 35 degrees.
Well, covering tracks it means I don't need to go back over that spot again. It's a time thing. Your need a deep shank to take care of the compressed ground.
   / Forward tine v reverse tine tiller #5
Tractor Time with Tim (on youtube) did a side-by-side comparison of the two types of tillers. Watching that might help with your decision.
   / Forward tine v reverse tine tiller #6
You don't have to go back over anything. If you see your tire track that means you never tilled it in the first place so you aren't going BACK over it. Bottom line is covering tire tracks is just a preference thing not a necessity. I have a box blade that is narrower than my wheel spacing. It doesn't bother me when I use it.
   / Forward tine v reverse tine tiller #7
Yea, one is better for hard ground and the other is better for softer ground. Mine is forward rotation I think. It cuts plenty deep enough for me.
Can't pull tires in. The area I'm looking to do it's about 2 acres and is the flattest spot I've got at 10 to 15 degrees. I might offset and keep that side high.
Box blades don't fluff soil.
If I had a smaller tiller centered, I'd have bilateral tire tracks. I would never get the track out and that part would be compressed, slowing down root growth in that direction. So yes, it does matter. And yes it may have been tilled already, but recompressed by a successive run.
I think I may have seen it. Reverse pulls down and puts rocks forward. Forward doesn't do those things, but is also cheaper and available in a wider track.
I'd rather "have" a reverse, but I don't know that I need it. Tractor is about 9000lbs.
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
