Forward Light Kit
   / Forward Light Kit #1
MikeyB
Parker,CO
JD 3320
I recently added a rear work light and it made a world of difference last night while moving snow and using my backblade. The front headlights of course get blocked by the loader which got me interested in the Forward light kit as well. Does anyone have it? In JD parts it is showing LVB25546 and I am curious where the light attaches on the tractor and if it just turns on with the headlights as the rear work light does.
Thanks,
Mike
   / Forward Light Kit #2
I had the same questions with my 4320. I have both front and rear auxilliary lights installed. The front lights mount on "brush guard" brackets available from JD that surround the factory lights on the ROPS. They are easy to install, but the brackets are pricey for what you get. The rear lights mount on the ROPS directly. The problem is when the headlights are on, both front and rear lights are on as well. The fronts can blind you when turning around to back up. My solution was to buy 2 JD work light switches (MIA 10204). I had to cut and splice the wiring harness that came with the ligths and I needed to buy more wire and wire loom to run everything over to my right fender. (Don't cut the factory harness if you can avoid it.) Now I can have just headlights, headlights and fronts, headlights and rears, or all three sets at once. I think at some point I will get a canopy and mount the fronts on it. The brush guards will be useless so maybe I will get two more lights to mount on them. I'll swivel them so I have lights on both sides. I dont think one can have too much lighting when working at night.
   / Forward Light Kit
Chris,
Thanks for the reply. I'm headed in the same direction that you went. After talking to my dealer and finding that I had to buy alot of extras I'm just adding two lights to the top of my rops using square u clamps and wiring it similar to yours. I am tapping into the worklight circuit at the fuse panel and adding a switch. That way the added lights only work with the headlights on but will be on a separate switch.
Mike
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2021 Ford F-150 XL (A53314)
2021 Ford F-150 XL...
23'x22' Double Garage Metal Shed (A53316)
23'x22' Double...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2016 Ford LCF Stake Body (A47477)
2016 Ford LCF...
