formula to figure concrete square yard needs
   / formula to figure concrete square yard needs #1
tcb
west alabama
kubota L4400
I lurked long before i posted and have learned much from the talent on this board so now i have a question. I thought i knew this but one supplier agrees with me and another is about two yards higher. garage pad to be poured is 20x35x.5 . i am coming up 9.7 yards or so, am i correct or wrong. oh and if there are any finishers on this board in alabama and they need something to do i will supply the BBQ. anyway all replies will be appreciated. i am doing all work myself and it has been awhile since i did finish work on crete so do not be afraid to throw out helpful hints and potential boo boos.
tim
   / formula to figure concrete square yard needs #3
Awesome link! I'm working on finishing a rather long concrete driveway and that link had a lot of useful information such as how wide and how often expansion joints should be placed. Thanks!
   / formula to figure concrete square yard needs #4
width x length x height
Are your measurements in feet? So the .5 is 6 inches?
Then 12.96 cu yd is what I get. (also the same with the calculator).
   / formula to figure concrete square yard needs #5
I came up with 10.80 yards (if your .5 means 5" thick).
5/12*35*20/27
Tim,
Not sure what your base is like but somehow concrete "disappears". If you order 11 yards, you "might" have enough but as it compresses your base and stuff, 11 yards might not be enough. Personally, I'd probably order 12 yards then have a small project lined up if there's any spare.
Brian
   / formula to figure concrete square yard needs #6
</font><font color="blue" class="small">( width x length x height )</font>
Yard of concret equals 27 cubic feet
{ width[ft.] x length [ft.] x height [ft] } / 27 = cubic yards.
Egon
   / formula to figure concrete square yard needs #7
Google does these type of calculations.
got to google.com and enter:
20 ft x 35 ft x 6 inches in cubic yards
click search and...
(20 ft) x (35 ft) x (6 inches) = 12.962963 cubic yards
   / formula to figure concrete square yard needs #8
I'm getting 12.96cu yds with my constuction calculator. I also assumed that the .5 is 6 inches
thanks to all, it appears i and one supplier were wrong and the least expensive is right. 13 yards x 67.00 is going to hurt but not as bad as some i have read on here. thanks again.
tim
   / formula to figure concrete square yard needs #10
Assuming that your measurement units are all in feet (you didn't say) and that they are completely accurate, the correct calculation is 12.962962 cubic yards. This rounds to 13. Concrete can be made by many different formulas. Some mixes can shrink and some can expand as they cure. Assuming you are using a mix whose volume will remain constant, I would ask them to make it the smallest increment higher than 13 that they are willing to. 13 and a quarter is what I'd order if they'd do that.
2010 CHEVROLET SILVERADO 1500 (A53843)
2010 CHEVROLET...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
Wolverine Skid Steer Hydraulic Drive Trencher, New (A52384)
Wolverine Skid...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
