Forks for FEL
   / Forks for FEL #1
Kenkjsm
Perryville, MO
Ford 4610 Utility, John Deeere 3020 Gas
I am looking for forks to put on my FEL. I would like to remove the bucket and attach the forks to the loader. All I seem to be able to find in forks for skid steers or clamp ons. I have a Ford 4610 Utility Tractor. I am located in souteast Missouri.
Thanks for your help
   / Forks for FEL #2
The best thing you could do for your tractor is convert it to SSQA. Doing that will open countless options for attachments.
   / Forks for FEL #3
Yup. Do this.
I built a set of pin on forks and hardly ever changed them..then I got another tractor and one had forks and one had a bucket. Then I got a machine with SSQA loader and sold both.
   / Forks for FEL #4
Crazy super expensive - Pin on pallet forks...
I'm building a set, have everything I need. Using and old hay bale frame that was a pin on, with adjustable mounts.
I just don't need forks so been slow to build this.
   / Forks for FEL #5
I took the pin on loader of my TYM T254 and converted it to SSQA with a Worksaver brand mod. Best thing I did for my tractor. I have a regular bucket, (had the SSQA plate welded on the back of the original), a set of forks and a skeleton bucket. The versatility of the the quick attach is worth it if you plan to switch between forks and loader.
   / Forks for FEL #6
Ken, call local tractor and farm equipment dealers and ask for help matching one of their fork attachments to your make/model loader arms.
I advise NOT to buy the clamp-on forks for your bucket, they will ruin it if you move heavy loads.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
197637 (A50459)
197637 (A50459)
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
LOT LOCATIONS (A51222)
