Fork lift project
   / Fork lift project #1
brewdog
NW PA
LS MT 225s, New Holland 3040, Kubota Z 422 - 60"
I'm just getting things tacked together. Using 2" x 4"x 1/4" steel tubing for the frame and forks.
http://www.tractorbynet.com/photos/data/542/24751000_0589-med.jpg
   / Fork lift project
Re: Fork lift project *DELETED*
Post deleted by brewdog
   / Fork lift project #4
Doug
We would like to see the photos but your site will not let us in.
Message"
<font color="blue"> Forbidden You don't have permission to access /photos1826/7/91/0/30/63/0/63300091709_0_ALB.jpg on this server. </font>
Al
   / Fork lift project
okay...I'll go there and see if I can fix it. This is the first time I tried to put a photo here.
   / Fork lift project #6
Hey, pls post some detail pics of your welding table. That looks NICE.
I need to build something--I currently use a hunk of 3/4 " plywood on two sawhorses--not the best.......
THKS.
ron
   / Fork lift project #7
Coming along good on the forks. How much weight do you expect to lift with it?
And how about a little info on that welding table. That looks pretty handy.
   / Fork lift project #8
The table sure looks like a Motorcycle lift to me. Most bike wrenchs own em. Always wanted one for myself, just found another reason why I should. Harbor Freight sells some.
   / Fork lift project
The weight I plan to lift with my forks shouldn't exceed 1200 pounds.
The welding table I made a couple years ago. The design has the hydraulic cylinder pushing the front lift arms and the top deck frame frame pulls the rear arms along with it. Once at desired height, lower the cylinder with the safety stop locking into position holding the rear lift arms and the cylinder holding the front lift arms. It's absolutely solid as a rock.
The frame is 2"x2"x1/4 angle top and bottom. The lift arms are 2"x2"x1/4" square tubing. I used 5/8" grade 8 pivot bolts top and bottom. I designed my table long enough to hold my motorcycle @ 8' long and 33" wide. The top platform drops to 10" off the floor with a max height of about 33". My ramp connects to end with the vice and I drive up the ramp with my motorcyle. I do have to remove the vice and mount the wheel chock to anchor the front tire. I'll get some more pictures of it. It's pretty simple to make.
   / Fork lift project
Here's the webpage that I saw these lifts on. They sell plans here in case you'd like to build one without the trial and error of flying by the seat of your pants. The are many many variations of this style of lift in the pictures section.
cycle lift web page
HLA LOT NUMBER 168 (A53084)
HLA LOT NUMBER 168...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
2010 MACK PINNACLE (A52472)
2010 MACK PINNACLE...
