Ford Select-0-Speed creep
   / Ford Select-0-Speed creep #1
iamaHawkeye
Southern Iowa
Foton 404, Ford 4000, Farmal H, 727 jd zero turn, 718 Grasshopper, Cub Kadet
New to this forum, so I hope this isn't a stale subject. My 1964 Ford 4000 creeps in neutral and Park. I've put it through a Ford specialty shop and they supposedly corrected it. Seemed to work for awhile. Is this a linkage issue? It is difficult to use it as a chore tractor, and certainly effects the resale. The S-0-S is great to use, but a pain if you want to stop.
   / Ford Select-0-Speed creep #2
have you went thru all the adjustments with the pressure gauges and the servo's, and also checked out the inching pedal.
what oil are you using? last time serviced?
do it cold or hot.. or both?
soundguy
   / Ford Select-0-Speed creep #3
It's funny how people ask a ? then never come back. I guess you could tell him to buy a shop manual, and read it.....But it doesn't matter anyway.
   / Ford Select-0-Speed creep #4
yep.. it's nice to hear back to see if they still have the problem or not?
soundguy
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
378813 (A51573)
378813 (A51573)
SDLANCH TRACKED MINI LOADER (A53843)
SDLANCH TRACKED...
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
