Ford Ranger problems
   / Ford Ranger problems #1
ToadHill
Elite Member
Catt county New York
Kioti DK35, Ford 8N, Oliver Cletrac
My son has a 93 Ford Ranger with a 4.0 engine and 5 speed tranny. The tranny seems to have packed it in. Does anyone know if the tranny from the 2.3 or 3.0 will bolt up to the bellhousing of the 4.0 engine?
   / Ford Ranger problems #2
I seriously doubt that would be the case but the best resource would be a wrecking yard---they have interchange books that will verify if'fn it will of if'fn it won't. .
   / Ford Ranger problems #3
I wouldn't think that would be the right choice, the 4.0 has a lot more torque than the 4 cyl, I'd think it will be a different trans.......
   / Ford Ranger problems #4
try and stick with the Mazda trans that came with the 4.0. I believe one from the 2.9 will fit, but you may get either a mitsubishi or mazda transmission. Before you put it in, service the slave cylinder and clutch, along with installing new plastic "cups" on the top of the transmission, they've been known to leak on the mazdas, leading to loss of fluid and meltdown. What is wrong with the transmission? The clutch has an annoying habit of becoming extremely spongy when very hot. The transmission has held up well, even when towing quite a bit of weight (55 sheets of 1/2" sheetrock along with 3 sheets of 5/8" fire resistent sheetrock).
Steve
   / Ford Ranger problems #5
Steve
Good thing you hauled "fire resistant" sheetrock---that may have saved you!! :~}
Thanks for the thoughts. My son just replaced the clutch and all the hydralics with it. A few days later the tranny stuck in first gear, we took off the sifter and with a screwdriver I was able to get it into second gear, but you still couldn't shift it. He was taking a slow ride to the shop to have his friend look at it and suddenly it started shifting like it should.
I told him to drain the gear lube, see if he can get a small magnet in the drain hole as he may have some loose chip from a piece of metal floating that jammed the shifter.
   / Ford Ranger problems #7
A lot of the info I use to look after my '99 Ranger I gather from the site;
The Ranger Station - Your Ultimate Ranger Resource
She just turned 155,000 miles, doesn't use a drop of oil between 6,000 mile oil changes, even when using synthetic, and still gets better than 23 mpg in mixed city/interstate/rural road travels. This is with the 3.0 litre V6 and Mazda 5-speed manual.
Steve
   / Ford Ranger problems #8
The M5OD is a good trans if you watch the plugs in the shifter housing as mentioned earlier. The bellhousing is different between each engine, so only a 4.0L will work(possibly the 2.9L, but I agree thats not the best choice) but there's allot of them arround if you can find one that has'nt been melted down....
This post made me think though.. It could possibly be that the pilot bearring is trashed. If is will stay in a gear, try shifting it without the clutch at "optimum" shift points. This will take the input shaft "wobble" out of the picture.. It could very well be a $5 fix with a bit of labor...
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
2012 FORD 4 DOOR TAURUS SEDAN (A54607)
2012 FORD 4 DOOR...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Power Glow LED 3500 Lumens Work Light (A52378)
Power Glow LED...
