Full Spool
- Joined
- Apr 7, 2020
- Messages
- 1
- Tractor
- Ford Powermaster 861
Hello All,
This is my first tractor and I had some questions regarding the carburetor and year of the tractor. The issue I am having is the tractor will only run with the choke on, once you ****** the choke to full position it stumbles and dies which
I know I have a lean condition. I have cleaned the carburetor, set needles 1.5 turns out, checked fuel flow, adjust main jet, with no luck. The carb is cast iron , 2-5/8" bolt spacing, and has a stamp of 458 on it, I was looking at ebay
to just buy a new carb but nothing has a 2-5/8" bolt spacing, I really can't justify spending $400 from a supplier for a new carb so I am looking for suggestions.
I suspect my issue is in the float mechanism as the needle tends to stick in the brass barrel sometimes, I even bought a new assemble and it still causes problems.
Also, how do I find out the year the tractor was produced?
Thanks,
Full Spool
Thanks,
Full Spool
