Ford NH 1920 front wheel drive hydraulic seal repair
   / Ford NH 1920 front wheel drive hydraulic seal repair #1
AlbionWood
Albion, CA
Ford NH 1920
While waiting for the injectors to get fixed, I might as well tackle the leaking left front wheel drive. Oil is leaking out of the top of the bevel gear housing, where the pinion gear housing goes in, so I suspect it's the seal between the two. I've ordered a replacement seal and am just wondering how tricky it's going to be to get the old one out and the new one in. Do I need a special puller to remove the old seal?
   / Ford NH 1920 front wheel drive hydraulic seal repair #2
Not familiar with that model, but most seals can just be pried out with a screwdriver, you are not saving it for anything.
   / Ford NH 1920 front wheel drive hydraulic seal repair #3
Exactly as @mjw357 said, not too tricky
   / Ford NH 1920 front wheel drive hydraulic seal repair #4
I believe the front axle configuration of a 1920 is similar to other NH Shibaura tractors. On my 1520, that seal is a two piece seal / sleeve assembly and when you disassemble the front knuckle, the inner sleeve portion will likely stay on the upper casting while the outer part will stay in the lower casting. No special tools required, just some care to not damage either casting. A previous post in the New Holland Owning & Operating section: "TC30 Spindle Seal(need a second set of eyes)" has typical photos. Inspect the bearings as you will likely see wear appearing as a dulled surface. My thoughts and comments about changing the bearings are comment #12 in that post, if interested.
Got this done! Getting the old seal out was a bit of a rodeo, as I didn't have a puller or a slide-hammer with a hook. Ended up just banging away at a heavy screwdriver, deforming the ring until it came loose. Once that was out the new one went in pretty smoothly. Just tapped it in with a rubber mallet.
I left the idler gear housing attached to the axle and dropped the bevel gear housing. Reassembly was a little fussy but went smoothly. I used a come-along from the rafter to hang the bevel gear housing and a small hydraulic jack underneath it to nudge it up into place.
All back together and not leaking at all!
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
2015 Kaeser M114 100psi Towable Air Compressor (A51691)
2015 Kaeser M114...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2019 FREIGHTLINER...
