dougmccabe
Hello! new to the forum and need some help. I have a loss of power under a load. The tractor ran perfectly before the incident.
Ford 1620 HST w/FEL. 2500 hrs
I tore the hyd filter and boss off in the woods clearing some old fields. I lost all of my hydraulic fluid and had to tow the tractor back to the shed.I replaced the boss and did a complete service (Hyd oil, engine oil, air filter, fuel filter, HST filter). I bleed the fuel filter, pump and injectors. I blew comp air backwards to the tank to clean any crude from the tank discharge screen. Cleaned the fuel filter housing passages. Checked the fuel hoses.
The tractor will run and move around under low power. When placed under a load the tractor losses power and will die if the load is not released ie: let off the treadle. Everything re-checked with no change. The tractor motor does not sound the same as it did before.
Ideas... fuel delivery issue, only running on 2 cylinders, injector bad, injector pump?
Hydraulics for the FEL and 3 pt work fine.
Anyone have this issue?
Thanks!
Thanks!
