Ford Newholland 8560 wont start.
   / Ford Newholland 8560 wont start. #1
Fudd
Havre MT
8560 newholland
I have a 1997 Ford newholland 8560 tractor. the other day my son was going to pull a friend out and this tractor still had summer fuel as it was minus 10F out the tractor started right up with the use of the glow plugs but. was not running right. I told him to park it at the shop and don't use it. a day later thought I should check this tractor out. it spun over but wouldn't start. I run the batteries down so thought I should put trickle charger on. I in advert hooked up backward for just a second the charge wrong, than changed it to the correct battery terminals. now the tractor will not even turn over it's like your trying to start it without pushing the clutch in. I checked all fuses everything looks good, I checked for fuses in line but could not find any. Ignition relay in the fuse box I have it on order from the local dealer, but had this relay apart and it looks good not burnt or any thing. doesn't smell burnt either.
   / Ford Newholland 8560 wont start. #3
Welcome to TractorByNet!
I moved your thread to the Ford/New Holland Owning & Operating forum. :)
FRONTIER MG20F LOT IDENTIFIER 78 (A53084)
FRONTIER MG20F LOT...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
Toro Zero Turn (A50324)
Toro Zero Turn...
