ford new Holland 4835
   / ford new Holland 4835 #1
Tim gurganious
conover .nc
4835 New Holland
I have a ford new holland 4835 starts and runs for a few minutes cuts off like its out of fuel wait a couple of seconds starts and does the same thing I have added fuel biocideI and blew out the fuel lines
any ideas of what the problem can be fuel pump maybe ? Thank you
   / ford new Holland 4835 #2
Clean the screen in the mechanical fuel transfer pump. Clean the debris out of the banjo bolt and fitting on the inlet side of the primary fuel filter ( water separator). Check the fuel line between tank & separator for pinch points.
   / ford new Holland 4835 #3
We had the exact same issue.... and found a large amount of debris in the banjo bolt where it comes from the tank, and enters the primary fuel filter. That took care of the issue. Thanks for the guidance!
   / ford new Holland 4835 #4
Had the same on my backhoe. Tank was full of rusty crud but the restriction causing the engine to shut off was in the banjo bolt at the sediment bowl. Mine had a 5/16" rubber line going to the bolt so I added an inline small engine filter to prevent future clogging. I have since replaced that filter 2 other times and keep some in my tool box.
2007 LUFKIN BELLY DUMP (A45046)
2007 LUFKIN BELLY...
2012 DOOSAN G25 GENERATOR TRAILER (A45046)
2012 DOOSAN G25...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A43004)
2020 INTERNATIONAL...
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
8' Container w/Side door & Window (A44502)
8' Container...
2017 Yale GLC050VX 3,500 lb LPG Forklift  Powershift, Aux Hydraulics (A44789)
2017 Yale GLC050VX...
