Ford New Holland 2120 brake friction discs
   / Ford New Holland 2120 brake friction discs #1
KJG
I bought this 2120 new in 1989 and have never had a single problem with it until now. Some of the brake friction discs have degraded and need to be replaced along with several of the friction plates. My question is that it takes 4 per side, 8 total and these parts from Ford New are ridiculously expensive. It would seem that there would be some way to cross reference these parts or at least find an after market replacement at a more reasonable price. Any help would be greatly appreciated.
A bit of advice. It is very possible that the friction discs degraded by not using Fords recommended hydraulic oil. The last time I changed the hydraulic oil I used Champion universal (one fits all) hydraulic oil. The problem started after putting the Champion oil in the tractor.
For those of you with sluggish hydraulics. What I noticed first was the hydraulics were action up and as was the shuttle shift. While I new the brakes were worn, it was because of his sluggish hydraulic problem that brought me to change the Hydraulic filter. (which had been changed when the Champion oil was put in) Long story short, the hydraulic filter was plugged with friction disc material. Ken
   / Ford New Holland 2120 brake friction discs #2
I'm sorry for the experience you are having. There may be a source of aftermarket discs, but I am not aware of one. There is little doubt that contaminated oil or an oil with the "wrong" additive package can cause this type of problem. Yours is not the first.
   / Ford New Holland 2120 brake friction discs #3
Hello, i can help you with that, we are from GOLDEN - manufacturer of Friction Discs, we can offer you very very reasonable prices compare to FORD. Could you give me your part numbers, we can give you our offer, we can supply in small or large quantities. email me at office@golden-india.com.
cheers
Rajdeep
   / Ford New Holland 2120 brake friction discs #4
   / Ford New Holland 2120 brake friction discs #5
A few years late but Tribco has many Ford/Ford New Holland discs on the shelf. Our parts are lined with a Kevlar fibered composite friction material, i.e., often we are more expensive but sometimes not. Call if you need any brake/clutch discs in the future.
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
2019 GMC Yukon 4x4 (MPV), VIN # 1GKS2BKC5KR183792 (A51572)
2019 GMC Yukon 4x4...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
John Deere 2955 Cab Tractor (A51573)
John Deere 2955...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
