Ford LS45 Lawn Tractor Problem
   / Ford LS45 Lawn Tractor Problem #1
Welman
Fort Fairfield, Maine
When I turn the ignition key it won't start and keeps blowing fuses. Please Help.
   / Ford LS45 Lawn Tractor Problem #2
Welcome from Oklahoma. You didn't give a lot to work with here. Quick answer is a short in the wiring harness, and/or a shorted solenoid or starter. If it only blows a fuse when you turn the key to the start position that is the circuit you need to tnspect. If it blow the fuse when you turn the key to the run position that's the circuit to inspect. Did anything unusual occur before this problem started, or did it occur after doing any other repairs or maintenance? Might not hurt to get a multi-meter and a book on electrical trouble shooting.
Ken
   / Ford LS45 Lawn Tractor Problem #4
Welman, still blowing fuses?
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
