Ford LGT14D
   / Ford LGT14D #1
mowermad
rockhampton, Queensland
ford lgt14d
Hi All
I am Val from Australia. I own a Ford LGT 14d tractor mower and a 23HP Valpandana. I live on 5 acres and use both tractors regularly. Presently I have a problem with my Ford/New Holland LGT14D. I had to remove the motor to take off the sump to repair after my drive shaft to the cutting deck broke and damaged the sump. When I replaced the motor and then reconnected the wiring to the starter motor, I created a short that burnt out the regulator. I have a new regulator now, but still seem to have a short when I try to reconnect the battery. I am hoping someone on this forum could take a couple of photos of the starter motor, so I can confirm that my starter motor and engine earth are hooked up correctly.
Your assistance would be greatly appreciated.
Cheers
Val
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
KUOBTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUOBTA M6800...
