Ford jubilee PTO lever stuck
   / Ford jubilee PTO lever stuck #1
PJMALLY
1953 Ford NAA jubilee
Recently used my tiller. Pro engaged and disengaged in garage. Tilled about 2 acres. Leaving field raised tiller stepped on clutch to stop PTO. Tried to push PTO lever forward to disengage PTO, will not budge. Tuned off tractor took tiller shaft off PTO as I didn't want tiller rotating. 3 POINT works fine pto shaft turns, PTO lever will not move forward to disengage
   / Ford jubilee PTO lever stuck #2
Take the side cover off and check the sliding collar will... slide. Ford NAA tractors are geared to fast for tillers unless equipped with a Howard after transmission that slows down ground speed. Sounds like you may have twisted the PTO shaft by forcing the tiller to work the ground faster than it should.
Cultipacker (A49251)
2008 Chevrolet Impala Sedan (A46684)
2008 Chevrolet...
Case International 8465 Automatic Baler (A49251)
Case International...
2021 Chevrolet Tahoe SUV (A46684)
2021 Chevrolet...
48" Skid Steer Pallet Forks  (A47371)
48" Skid Steer...
Wolverine SP-15-84W Skid Steer Snow Blade (A47371)
Wolverine...
