Ford jubilee hyd. issue.
/ Ford jubilee hyd. issue. #1
Bigdaddygb
Pennsville, NJ
Ford jubilee
Hello everyone. New guy here. I have used to the search on here and didn't see my exact problem so..... I have a 1953 Ford Jubilee I got that runs pretty good I thought pump was bad since I pulled the plug on top of hydraulic cover under seat and had no fluid at all. Now since I have rebuilt hydraulic pump I have fluid coming out while at idle. but..... now my arms won't move at all. when I lift them I get no pressure but if I put air in the bleeder bolt I was just talking about on top of cover the arms go up and down no problem. rather fast too with little air. Wife wants to kill me... every time I say hey I need this for tractor or that for tractor.. I had to buy new battery, new battery cables and new starter and rebuild the pump already. Any help in narrowing it down to a part would be great. liftcover.jpg
/ Ford jubilee hyd. issue. #2
:welcome:
To the TBN forum Bigdaddy. You came to the right place to get answers.
I can't help but someone on here will.
already figured it out. previous owner had hydraulics rebuilt. Looks like a shoddy job. pulled cover and pulled check valve was stuck with ball stuck to bottom of check. pulled ball off it was rusted to check valve. cleaned it up and reinstalled. they never hooked up pressure passage connection to pump. Fixed both things and it works fine now.
/ Ford jubilee hyd. issue. #4
Great work and thanks for posting your resolution as it may help someone else later. :drink:
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
CASE INTERNATIONAL FIELD CULTIVATOR (A63290)
CASE INTERNATIONAL...
BLANTON PULL TYPE DRAG HARROW (A63745)
BLANTON PULL TYPE...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59910)
2016 FREIGHTLINER...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
