Ford Jubilee 3 point hitch problem
   / Ford Jubilee 3 point hitch problem #1
Gustavison
I just bought a ford jubilee made the mistake of not trying out 3 point hitch. If I raise it the slightest amount it automatically goes to the top of the range. Transmission fluid/hydraulic all look as if just changed. Someone told me it may have an airlock and need to be bleed. Any advice. Thanks.
   / Ford Jubilee 3 point hitch problem #2
air int he hyds would not cause that.
check to make sure you are in position control, not draft control. small 3" lever straight up for position control.
post back.
past that may be out of adjustment with wear onthe cam follower pin, or the cam itself.. and some one may have didled with it to try and correct it.
soundguy
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
Auger for mini skid steer (A53421)
Auger for mini...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2011 DRAGON PRODUCTS 130BBL VACUUM TRAILER W/FRUITLAND VACUUM PUMP (A53843)
2011 DRAGON...
WOODS PTO SIDE MOWER (A53843)
WOODS PTO SIDE...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
