Ford F150 issues
   / Ford F150 issues #1
ToadHill
Elite Member
Catt county New York
Kioti DK35, Ford 8N, Oliver Cletrac
I have a Ford F150 4.2L with auto trans. Recently it has developed a problem I can't seem to figure out. When I get up to 55mph or above and cruse along I suddenly get what feels like a high speed miss, or momentary hesitation. If I kick it into passing gear, the miss goes away but will come back when I slow back down. I never have the problem at speeds around town.
I've changed the plugs within the last 300 miles. The fuel filter has only a couple thousand miles on it. The miss doesn't seem to cause the check engine light to come on.
Anyone have any suggestions?
   / Ford F150 issues #2
If you have an electric locking torque converter, it may be acting up. Locking and unlocking, which isn't really abnormal in the Chevys I have owned. It will cause the truck to lurch a bit and you will see engine speed go up and down a hundred RPMs or so. I used to notice it on my Chevys at 50 MPH. So I would drive 55. When my converter locked up and would not unlock, I found the wire that went to the bell housing and pulled it off. Never had another problem. You may want to disconnect it as a test.
   / Ford F150 issues #4
I had a problem like that recently and it turned out to be plug wires.
   / Ford F150 issues #5
Check your throttle position sensor. I had my dodge ram 1500 doing exactly that.. went to the dealer they did a trans service.. didn't fix it. Later on I was setting at a stop light and the engine surged in rpm BIG time. had i not had my foot ont he brake good, the truck would have lurched. I took it IMMEDIATLY to the dealer again.. who then repalced the TPS... that fixed it.. never has done it again.
soundguy
2017 FORD F550 XL SERVICE TRUCK (A51406)
2017 FORD F550 XL...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A54757)
UNUSED RAYTREE...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
Year: 2007 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 147,891 Plate: Body Type: 4 (A55788)
Year: 2007 Make...
