ford diesel injection timing on 192
   / ford diesel injection timing on 192 #1
jeffd
cass city, MI
TC24DA
I got an old ray-go loader with a 192 Ford diesel. Was a basket case. Got it back together but have some timing issues. I do not have a manual, so far the only thing that has me stumped is the injection timing. I can time the pump, but dont know where to time it with. I have pulled the #1 injector out and brought the piston to TDC, but that wont work, because that is gas engine timing. Any help would be appreciated.
Here, I will answer this for the next person looking.
The timing marks are on the flywheel, on the same side of the engine as the injection pump. There is a little cover, over a hole about the size of a quarter. Get the engine near TDC on cyl 1 and the timing marks are stamped in the flywheel. The timing of the injection pump is done through the little window on the pump, held in place with 2 screws. This cover needs to be in place when trying to run the engine. I believe the setting is 23 degrees.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53473)
2021 NEW HOLLAND...
FAKE (A52472)
FAKE (A52472)
ASSET DESCRIPTIONS & CONDITION (A54607)
ASSET DESCRIPTIONS...
