Ford BH 758
   / Ford BH 758 #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
I saw a Ford 758 BH for sale for $1200. It's on a 8N now with some home made attachment. What's this beast worth? What are the capabilities?
   / Ford BH 758 #2
I recently sold my 758 with frame mount for a 2120 for $3500 to my dealer. It was 15 years old and had done a lot of work.
Andy
   / Ford BH 758
The one I'm looking at is a small unit. Eitherway, it seams like a price that could get me a BH to have around for the occasional use. Was yours a small unit? I called the Ford dealer for specs and I'm not sure if I was getting an accurate description.
   / Ford BH 758
I'm back. I bought it. The salesman, hardly the corect term, was real good. My decission process draged on. It was not the cost but the application of a small BH. A small BH is not and can't compete with it's larger counter part. So in the end if you think you have enough small projects that either don't require the full BH called in or want to do them on your schedule, get one.
I was trying to justify the cost of a new one. I couldn't do it. There's many toys I would choose first. So this older used beast was just perfect, a $1200 fixer upper. I desidded to buy now and if it turned out to be not what I could used, I'd sell her to the next tractor dreamer like me.
She has been modified from the original setup. The unit has had a frame made for a quasy sudframe attachment. This was setup to be mounted on a Ford 600 series tractor. It was mounted to the rear axels at the fender attachment as well as the 3 point attacment. The control valves that control the stablelizer arms/legs were replaced with a seperate system. Now located just to the right on the seat. The down side to this is it's on a seperate hydro-circuit. There is a lever shut off that in one position alows for up/down of the stablelizers and the other position for bucket/digging operations. The external pump mounted on the PTO appers new.
Now I'm looking for a 4wd tractor to mount her on. My early X-mass present.
Patrick
JOHN DEERE 54D LOT NUMBER 86 (A53084)
JOHN DEERE 54D LOT...
UNUSED X-STAR 70" QUICK ATTACH MANURE/SNOW PUSHER (A51247)
UNUSED X-STAR 70"...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
SKYJACK SJIII 3219 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3219...
