Ford 9n tractor brakes
   / Ford 9n tractor brakes #1
Onustock
Over the past several uses the brakes seem to not want work that great
   / Ford 9n tractor brakes #2
Have you tried to adjust them, since they are mechanical and have no hydraulic assist, as they wear down the peddle will not exert as much pressure on them if the stroke is too long.
Look for a square pin sticking out of the backing plate and adjust it until the brakes get tight then back off 1/2 turn.
Remember that mechanical brakes were never the best system but they should work "ok" at the speeds a tractor travels.
   / Ford 9n tractor brakes #3
Check your axle seals, hyd. fluid may be getting on the brakes. One trick for this is to run it about a gallon low on hyd fluid.
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2021 JOHN DEERE 7R230 LOT NUMBER 208 (A53084)
2021 JOHN DEERE...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
