Ford 9600 fuel leak
   / Ford 9600 fuel leak #1
jhp123
VA
1965 ford 5000 2000 new holland 1920 4wd, 1974 ford 5000, 1975 ford 9600, 1988 case Ih 885
We have a 1975 ford 9600 6 cylinder tractor. While running, diesel fuel is coming out of the small tube (overflow) on the fuel injector pump. Engine is running fine but the fuel is coming out pretty fast out of the tube. The pump is exactly like my 5000 with the exception of the 2 extra ports (6cyl vs 4) Anyone with any experience with this problem?
   / Ford 9600 fuel leak #2
Replace the fuel transfer pump which is bolted to the injection pump. Then change the oil in the injector pump.
Thank you, we pulled the lift pump off yesterday and fuel poured out from the injector pump. Manually pumped it and it definitely had a hole in it. Just happy it's a cheap fix!
10 in Small Excavator Bucket (A52377)
10 in Small...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
20' BI-PARTING GATE (A51248)
20' BI-PARTING...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
