ford 960 steering cylinder
   / ford 960 steering cylinder #1
52 8n
pennsylvania
ford 8n
Hello, recently me and my grandfather overhauled this tractor from front to back tires, rims, motor,electrical. Now we can not find a steering cylinder to finish this project, does anybody know where i can find one, or one that will work of another tractor. Thank you.
Ok thank you
   / ford 960 steering cylinder #4
   / ford 960 steering cylinder #5
Start with All States Ag Parts.
All States Ag Parts | Tractor Parts | Combine Parts | New | Used | Rebuilt | Online
If they don't have that cylinder in stock, they can find it for you.
I buy stuff from them regularly. No problems.
Good luck.
not knowing what a ford rowcrop steering cyl is means you sent that guy on a long, long, fruitless search!
the ford rowcrop cyl is a special little deal with control valve built in the end. rod end of cyl is mounted to a bracket and fore end with the valve is to the front steering pedistal sector arm.
steering box sector arm mounts to a draglink that is slightly bent and runs to the valve on the steering cyl
quite a special arangement.
Actualy tractor parts asap has a reman cylinder in stock that i will probably buy. And it is for 900. I will be glad when i donte have to sink anymore money in this machine already more in it than its worth.
   / ford 960 steering cylinder #8
yep. I've heard of a few places that will cut ford cyls apart and fix them. getting harder and harder to find that type of service.
I donte need the cylinder part that does not leak. Mine leaks out the end where it mounts by the spool valve i already put the new seals and o rings in it but it still leaks.
   / ford 960 steering cylinder #10
Good luck, might have to get a good used or reman one
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
Reinco Straw Blower (A50774)
Reinco Straw...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2003 Chevrolet Express 1500 Cargo Van (A50323)
2003 Chevrolet...
2022 Bobcat T66 (A50120)
2022 Bobcat T66...
Ditchwitch 1030 Walk Behind Trencher (A50121)
Ditchwitch 1030...
