Ford 917 Blade Style Question
   / Ford 917 Blade Style Question #1
wirlybird
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
So I am getting ready to order new blades for the Ford 917 (22-184)
Flail Master has two style I am interested in. See picture, the ones with red arrows.
I will be mowing a flat (10 acres) and maintained field. No rocks, or other debris. Probably mow at about 3 inches and it will be kept mowed.
The blade on the left in the picture is $5.50 (need 33) and the one on the right is $1.75 (need 66)
Which blade would you guys go with? Is there really enough difference to justify a $2.00 per station difference?
   / Ford 917 Blade Style Question #2
Having used both, and as I mentioned before, the 2 piece blade will leave a rippled effect across the field. It may not be that noticeable at the 3" height. IF that is not an issue, I would go with the 2 piece blades, easier to sharpen, double sided blades and cheaper.
   / Ford 917 Blade Style Question #3
The problem that you will have mowing at a three inch height is being able to create enough of a pressure gradient/suction to lift the grass and brush up and slice it and not using the side slicers for mowing will not let you recut the material to a finer clipping and allowing it to dissolve sooner.
PALLET OF DRAINS / DRAIN GATES (A51244)
PALLET OF DRAINS /...
UNUSED NORTHERN UTV-50 AG MIST SPRAYER (A51243)
UNUSED NORTHERN...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
New Holland...
Champion C80 B Motor Grader (A50322)
Champion C80 B...
