Ford 8N fuel problem?
   / Ford 8N fuel problem? #1
denden1960
I am trying to help my uncle with his 1952 Ford 8N. It will run as long as you are spraying starting-fluid into the carburetor. He has rebuilt the carburetor, and that did not help. He took the carburetor off a second time, and went through it to make sure that he didn't miss anything. Everything seems to be in order. Does anyone have any suggestions as to what to look for?
   / Ford 8N fuel problem? #2
Is gas getting to the carb?
There may be a filter screen inside the tank, or the fuel line could be blocked
The Carburetor is full of gas.
   / Ford 8N fuel problem? #4
time for another rebuild.. this time going thru it completely after a soak in a dip style cleaner. then go at all the ports with fine wire and then compressed air thru the ports.. new gaskets, new seat seals, new choke packing, new throttle shaft seals.
a GOOD rebuilt kit is about 40$.. ot you can put your money toward a new repop carb for about 90$ ..
soundguy
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
JOHN DEERE LOT NUMBER 138 (A53084)
JOHN DEERE LOT...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
