ford 8N front dist. how to settiming?
   / ford 8N front dist. how to settiming? #1
macv88
plant city,fl
ford 8N
how to set - advance - timing on frt dist ford 8N ?
   / ford 8N front dist. how to settiming? #2
if it was ok when you pulle dit..it's ok now.
that said.
flip the manual open to the diagram showing the dizzy. have a ruler and a 1/4" drill bit handy.. plus a screwdriver.
an ohm meter will help but is not needed as you can do it all by measurement.
ps.. there ain't a hole lot of timing on a front mount ;)
   / ford 8N front dist. how to settiming? #3
View attachment pg10.pdf
View attachment pg11.pdf
View attachment pg12.pdf
since you obviously don't own a service manual.. i scanned the relevant pages of mine for you. describes it and has a pic showingthe straight edges... etc.
way wasier to look at than to tell someone over mail.
here are the 3 pages from the fo-4 service manual that cover setting timing on a front mount dizzy ( 9n/2n or early 8n )
you really should invest in getting one of these manuals if you are gonna use that tractor.
   / ford 8N front dist. how to settiming? #4
Here is a service manual pdf.
1262 (A50490)
1262 (A50490)
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
2006 CATERPILLAR 252B SKID STEER (A51246)
2006 CATERPILLAR...
