GManBart
Elite Member
- Joined
- Dec 10, 2012
- Messages
- 4,976
- Location
- Detroit, Michigan
- Tractor
- Massey Ferguson 241, Kubota SVL90-2
1948 Ford 8N, pretty much in original configuration. I was skidding some trees out of the woods, and ran the tractor for about an hour, with no problems. Heading down my driveway I opened the throttle a bit, heard a metal clicking come from the fan blade/shroud area a couple of times, and before I could cut the throttle, the fan blades hit the shroud pretty hard, saw a couple of sparks, and the engine quit. The shroud had cracked all the way through in one spot, causing the contact (there are a couple of other small cracks. I checked all the wiring, and everything looks the way it should (just had the hood off last month). I can't find any obvious damage, but it won't start...turns over fine, but that's it. I haven't pulled a plug wire to see if it's getting spark yet (it was really cold, getting dark, and I had to pull it out of the driveway).
I'm wondering if the fan blade strike could have thrown the timing off? I'm a novice at flathead engines, so I'm not even sure if that can happen the way it could with OHV engines with camshafts running off a timing chain. Thoughts, guesses? R,
Bart
Bart
