Ford 8n Fan Belt Replacement?
   / Ford 8n Fan Belt Replacement? #1
blount2000
Middle Tennessee
1949? Ford 8n
On an 8n with a front mount distributor, is changing the fan belt as simple as loosening the generator bracket, slipping off the old belt, and then slipping on the new belt? Or do you have to remove stuff to get access to the the old belt to take it off & put the new belt on?
It just seems like there is not much room/clearance between the fan/radiator or between the bottom pulley and such.
   / Ford 8n Fan Belt Replacement? #2
Best I can recall, nothing had to be removed, just enough room between fan and radiator.
   / Ford 8n Fan Belt Replacement? #3
there is just enough room between the fan and shroud. You might need to rotate the fan while you are working it in. My belt usually breaks when I'm at the farthest point from my barn :mad::mad:
Jeff
Thanks for the responses! It sounds like I'm in luck and replacing it should be fairly straightforward.
Mine hasn't broke yet, but it has started squealing at higher rpm's and is looking a bit frayed around the edges.
I figured it would be good to go ahead and replace it before it actually breaks!
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
