Ford 8N 12v Battery
   / Ford 8N 12v Battery #1
fibrostic
I did a 12v conversion on my 1952 Ford 8N last night, and think everything is ready for me to drop in the new battery. Does anyone have a recomendation for a napa (the store next to my office) battery that will fit?
   / Ford 8N 12v Battery #2
the bat tray will accomodate a group 1 6v bat, so you need a 12v bat of similar dimensions.
grp1 = 9 1/8 L, 7 1/8 W, 9 3/8 H
thus, just running down the group chart, any of the following will fit within those specs.
21, 22r, 25,26,35,52,54,55,61,62,70-73,75,85,86
I'd like to point out I would not reccomend the 'reversed' terminal unit, .. though you could do it if the cables are long enough to reach without interference., also, the grp 52 is a pretty small battery 5 13/16 width.. likely the narrowest one in t he list etc.., .. probably smaller than the rest. you may actually need a wood block to 'bushing' it in place.. it will have a lower CCA capacity.. but then.. 12v bats on a 6v starter actually work pretty good, low capacity or not.
also.. there are at least 5-6 other batteries that were 1/8-1/4" larger in length or width than the grp1 bat, i did not include those.. but it's likely they would fit as a grp 1 6v bat still has a scoth of play in the bat tray. Don't try to go larger than the Height number as you will have battery post / gas tank issues!
hope that helps some..
soundguy
Kawasaki NR (A50324)
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
UNUSED RAYTREE RMAU2 AUGER (A51248)
UNUSED RAYTREE...
