Larry48
I have an unknown 12 volt conversion on my 8N. The guy mounted a push button starter button on the dash to put 12 volts to the solenoid. I want to use the Ford push switch on the transmission for starting. I need a 12 volt solenoid that I can put 12 volts on one of the 2 small terminals and use the Ford push button switch to ground the second terminal to start it. I can't find diagrams on solenoids and no one in parts stores can talk solenoid coil wiring. does anyone know a solenoid that would work this way?
