Ford 860 - Oil Pick-up Tube
   / Ford 860 - Oil Pick-up Tube #1
blong99
Basehor, KS
1957 Ford 841, 1955 Ford 860
I was recently changing the oil on a ford 860 I just acquired and noticed that when I removed the oil pan plug there was no screen attached to it, so I ordered a new plug with screen. When I went to install the new plug, it would not go into the pan, and it was then that I noticed that the oil pick-up tube (probably not the correct term) was bent and off to the side in the pan opening (so there was no way to get the screen up into the pan). I have a couple questions related to this I was hoping you all could help me with:
1) Is there any harm to running it without the screen on the plug? I talked to a local guy and he said he rarely sees any accumulation of debris on the screen and by changing the oil filter with each oil change I should be fine - is this good advice?
2) Even though the tractor runs 40-50 lbs of pressure consistently, should the fact that the tube bent cause concern (is it more likely to fail or quit working)?
On another note, the proofmeter does not work. I just replaced the cable and that did not help. I disconnected the cable from the proofmeter, ran the tractor and the cable is spinning. Would the next step be to replace the proofmeter?
I am still learning about these tractors so any feedback would be greatly appreciated - thanks in advance!
Brett
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2023 LMC H40024 LOT NUMBER 176 (A53084)
2023 LMC H40024...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
INDUSTRIAL UNISAW TABLE SAW (A51248)
INDUSTRIAL UNISAW...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
480/70R38 LOT NUMBER 121 (A53084)
480/70R38 LOT...
