matt19370
I'm looking for confirmation before I jump in and split the tractor. I ran the bush hog for about an hour a couple days ago, when I got back to the house oil was dripping out of the weep hole in the bottom transmission inspection plate with the cotter pin in it. I know that is what it is there for and have seen the occasional drip before, but this was a steady drip. I pulled the plate and everything inside is coated with hyd/gear oil. I don't see the hydraulic lines spraying, so my though is input shaft seals are bad. My only concern is that there is a coating of oil on everything in the housing I would have expected a seal leak to run down the front of the transmission and out. Any insight would be appreciated. Thank you.
