Ford 850 starting problems
   / Ford 850 starting problems #1
chrishamm850ford
1957 ford 850 w FEL
So today its about 30 degrees and my Ford was difficult to start. Choke or no choke finally get it started and I put my quick hitch on and start grading my driveway. The thing cuts out when I put it under load . I finally get it restarted and back up the hill to the garage and it doesn't even want to start warm. It does put out a puff of blue smoke when I first start her. HELP!
   / Ford 850 starting problems #2
Check the air cleaner - it HAS to get air. Check the fuel supply - the needle on the float may sometimes stick. Perhaps you've got a bad rotor or a cracked distributor cap. Maybe the gap on the points is a bit off. you have a number of points of potential failure but if you get fuel, air, and spark it should go.
1992 GROVE AP-308 CRANE (A51222)
1992 GROVE AP-308...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
