I agree completely, the electronics on these tractors are a nightmare. I have the wiring diagrams and the transmission book, and still it can take hours and hours of testing and troubleshooting to locate problems sometimes. If the tractor has rod linkage it's an early model, so the clutch cable should not be a factor. My book shows a couple possibilties for E28, with the tractor not moving and lift not working - one is a problem in the closed center lift system, another is the low pressure system is too low. Should be 250 to 280 psi. Does it have closed center hydraulics? I haven't seen any closed center tractors in this area. I'm not sure how much help I can offer from this distance, other than what the error codes point to. Is your mechanic experienced on these transmissions? They're just not easy to diagnose, even for someone with experience.
