Ford 841 Power Steering Valve Nut Adjustment
   / Ford 841 Power Steering Valve Nut Adjustment #1
strum456
Platinum Member
Westmoreland County PA
Fords
New Holland (841) - 4 CYL AG TRACTOR ALL PURPOSE (1/58-12/64) Parts Diagrams
Does anyone know the procedure for tightening #43 "Bearing Lock Nut"?
My manual says to "tighten it until firm, then back it off 1/6th of a turn".
My power steering was really sluggish. It took a lot of force to turn the wheel, and you couldn't turn it very fast. This was especially irritating when trying to make a quick turn when backing up a wagon or raking hay.
I decided to try tightening nut #43. Just by testing it in the garage, the steering seems to have improved. I turned it 1/6th turn tighter than it was, but I was wondering if anyone knows the correct procedure.
   / Ford 841 Power Steering Valve Nut Adjustment #2
If you have gone through the work of pulling the steering wheel and getting the tin off you might as well pull the hydraulic block and clean/inspect the springs and plungers in there.
Also, you want to install new upper and lower seals since you are in there that far.
Done. I'm just not sure what is meant by the word "firm". Would that be referring to tightness on the wrench, or is it tightness on the bearings, like the castellated nut on a wheel bearing, for example. Should I flatten out that belleville washer and then back off the nut 1/6th, or would that be hard on the bearings?
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
1992 GROVE AP-308 CRANE (A51222)
1992 GROVE AP-308...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
1992 New Holland L553 Skid Steer (A50657)
1992 New Holland...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
