Ford 821 with 19-97 Loader
   / Ford 821 with 19-97 Loader #1
corvettteguy
NE PA
ford 821 19-97 sherman
I bought long ago a 821 ford loader backhoe
ans it came to me with a
Jeep motor.
The motor is gone and some of the bracing mounts are
now removed and I have picked up a 800 engine
that I plan to install.
The 19-97 ford loader will make it very difficult
to lift the motor over the frame so I would
like to remove the loader.
My question is
After removing the 1" pins under the rear axle, what bolts have to be
removed from around the front axle?
Also does the pump and mount remain on the loader whe4n it is
removed?
   / Ford 821 with 19-97 Loader #2
got a strong tree to park under to swing a chain from? I like to swing laoders and back out from them.
pump setup may be changed.. see if it is attached to fram or not. if machine was re-powered.. who knws what was changed with the front bolster.
I am removing the long bolts on the front support plate
And the short bolts. But the pump mount plate may not
stay attached to the loader which also
bolts through the front support plate corners.
(3) FLOOR JACKS (A53843)
(3) FLOOR JACKS...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
RIGID 141 PIPE THREADER (A53843)
RIGID 141 PIPE...
SKID STEER SCARIFIER ATTACHMENT (A53843)
SKID STEER...
