Ford 801 powermaster Power steering questions
   / Ford 801 powermaster Power steering questions #1
hvb555
williston,fl
1956 ford 801 powermaster
I have a 1956 Ford 801 Powermaster with factory power steering. I dont use the tractor that much and over the years have repaired the power steering parts hoses, cylinders, used pump etc.
I have just decided to take all the power steering off the tractor. If I do this how will it act. Will I have to replace the steering box? This is my main concern.
Would appreciate and help or advice. Thanks
   / Ford 801 powermaster Power steering questions #2
1, if you have a 1956, you don't have an 801
Yr models 55-57 were 00 series. Ie 800 ( add middle digit to series number to get model Id, for instance an 800 with a 4 SPD trans is an 840 )
Year models 58-62 were 01
Now, on ag models, the steering box with dual sectors and valve block go as an assembly with the pump, lines, and cylinkers, and if technical, then the drag links and radius rods.
If you want to go to non PS, you should swap in a manual box.
Do you not like the PS?
   / Ford 801 powermaster Power steering questions #3
Factory PS in 1956? It wasn't added until 1957 Mid production run. As soundguy said change to manual box. Or take the belt off and mussel it out. Got to love that strongarm steering, NOT. I'd be fixing that PS.
Kirk
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2019 Takeuchi TL8 Track Skid Steer (A50860)
2019 Takeuchi TL8...
Miller Millermatic 251 Welding Machine (A50860)
Miller Millermatic...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
