Ford 7740 Hour Meter Problem. Please Help.
   / Ford 7740 Hour Meter Problem. Please Help. #1
dparks58
Goochland, VA
Ford 7740
I have a Ford 7740 and the hour meter just recently stopped working at about 1560 hours. The tach and all the other guages work fine. All the guages seem to be powered electrically, but the hour meter itself is mechanical, not digital. Does anyone know where the hour meter gets it signal? Do the tach and hour meter get their feed from the same place? That might indicate that the hour meter itself is broken/stuck since the tach works. I would really appreciate any help.
   / Ford 7740 Hour Meter Problem. Please Help. #2
yes the feed off the same place
Thank you. I may take it apart then and see if I can figure out why its not turning. Someone posted earlier in another forum that they had the same tractor with the same problem and that a plastic gear in the counter had broken a tooth. It may be a problem common to this tractor. Thanks again.
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2019 FREIGHTLINER CASCAIDA TANDEM AXLE SLEEPER TRUCK (A50505)
2019 FREIGHTLINER...
40 Yard Roll Off Container Dumpster (A49346)
40 Yard Roll Off...
2023 Bobcat E32i Mini Excavator (A48837)
2023 Bobcat E32i...
2014 Ford F-250 Knapheide Service Truck (A48081)
2014 Ford F-250...
2005 Ford F-350 4x4 Crew Cab 8ft. Mason Dump Truck (A48081)
2005 Ford F-350...
