Oil & Fuel Ford 7710 Injector and Lift Pump Question
   / Ford 7710 Injector and Lift Pump Question #1
DR7710
LaGrange, GA
Ford 7710 II
I have a 1989 Ford 7710 II. It was running great until I ran all of the fuel out of the upper tank and only had fuel in the lower tank. I did some research and thought that my fuel lift pump must not working. Well, after looking at my repair manual, it shows a completely different type of injector pump than what is on my tractor. :confused: ... So after more researching, it appears that what is on my tractor is a rotary injector pump. I attached a picture so hopefully someone could confirm.
Does a rotary injector pump use a lift pump like an inline injector pump? If so, where is it located and can it be rebuilt? I'm new to this type of system so any help is greatly appreciated!
Thanks,
Doug
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
2024 BRAZOS 53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
