Ford 7108 Loader Hyd Connect Problem
   / Ford 7108 Loader Hyd Connect Problem #1
billyboy35
Lake Pomme de Terre, MO (Wheatland)
Ford 1715
I am trying to connect hydraulic lines (quick connect fittings) and can't physically push the two together. Any help on this please? Thanks
   / Ford 7108 Loader Hyd Connect Problem #2
You might have to release the pressure on the implement or tractor, or both.
Have you tried tapping the balll inside the QD and releasing some fluid.
You could push the male QD ball against a hard surface.
   / Ford 7108 Loader Hyd Connect Problem #3
ditto what J_J said. we wrap a rag around the face of the male then slap it down on a hard surface to make it equalize pressure.. should connect up then, if the connectors are the right type to mate up..
   / Ford 7108 Loader Hyd Connect Problem #4
I have to do that sometimes... I noticed the QC for the curl function are leaking slightly. Are the QC replaceable or is replacing the o-ring an option?
Thanks, Mark
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
