Ford 7.3L Gas Engine
   / Ford 7.3L Gas Engine #1
Tractorable
Veteran Member
Marshall, Va
Tractorless, 2019 Toyota Tundra, 1980 Toyota Land Cruiser FJ40
Specs were just released on Fords new 7.3L gas motor, 430hp and 475lb/ft of torque. Cam in block push rod motor, forged crank, pistons/rods ready for boost, 4 bolt main bearing caps, cast iron block, built for durability, longevity, simplicity, and ease of maintenance. Makes 400lb/ft of torque at 1500rpm and will be mated to a beefed up 10 speed auto trans.
I like it, more power for towing than the 6.2L, and should last forever and be cheap and easy to maintain. I bet it’ll make a heck of a drag motor with a supercharger or a couple hair dryers bolted on.
We Finally Know the Ford Super Duty 7.3L V8 Power Numbers & They Are Lower Than We Thought! - YouTube
   / Ford 7.3L Gas Engine #2
Interesting. I sure wish when they do these interviews they would step away from the background noise. That said, I think it is smart of Ford to redo the big gas engine. :thumbsup:
   / Ford 7.3L Gas Engine #3
You shouldn't believe everthing you are told,I don't.
   / Ford 7.3L Gas Engine #4
I think it’s rated at 4000 rpm not 1500 but the 400 foot pounds seems believable.
   / Ford 7.3L Gas Engine #6
I think the old GM 8100 (8.1L) was 330hp at 4200rpm and 450ftlbs at 3200rpm. It was a real torquer but drank fuel.
   / Ford 7.3L Gas Engine #7
I have serious doubts about the new 7.3 gasser being any better. Big displacement high output gasser and good mileage doesn’t go together. The 8.1 hasn’t been produced in 10 years but I’d still think that over a Ford anything. I hope the scraped the duel timing chains and plug spitting problems.
   / Ford 7.3L Gas Engine #8
I don't know why people make a big deal about the plug spitting problem I have 2 v 10s and have only lost 2 plugs at a cost of 75$ a piece to replace. The motors have 425,000 and 497,000 and still going strong daily driver. No other engine repair done to them !:cool2: Best gas engine since the 460....:drink:
   / Ford 7.3L Gas Engine #9
Wonder what the gas mileage will be with it? I'm guessing maybe 15 hwy, 10 towing? If you gonna work the horses you got to feed them.
   / Ford 7.3L Gas Engine #10
Maybe in a 250. I’m guessing the medium duty truck is closer to 5 mpg loaded. I’d be surprised of it got 10 towing a big load in any truck.
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
