Ford 6710 540 to 1000 pto switch
   / Ford 6710 540 to 1000 pto switch #1
drkluke
oklahoma
ford 6710
Does the clip on the pto look the same as a deere. I can’t see or feel any clip like my 4240 has to flip over the pto shaft. I have seen Some 1000 pto shafts but this tractor looks to be a fixed shaft. All over the tractor is gives the rpm speed for 1000 and 540. I have a claas contour disc mower with 1000rpm shaft. If I put a adapter and idle up the 2100 for the 1000rpm speed would it would correctly. Thank you
   / Ford 6710 540 to 1000 pto switch #2
If there is no clip then it is a 540 rpm PTO only.
The decal is the same wether with the dual PTO option or not.
The PTO will turn only about 580-600 rpm if going full engine rpm.
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2012 DODGE DURANGO SUV (A52576)
2012 DODGE DURANGO...
