Ford 6700 draft leverh
/ Ford 6700 draft leverh #1
Greydodge09
Northwest
Ford
We have rescently purchased a Ford 6700 in descent condition, and everything seems to work fine, but the draft/position lever is stuck in draft mode. I have only tried to pull on it by hand, not wanting to break anything by beating on it or prying. Anyone have any tips for freeing the stuck lever?
/ Ford 6700 draft leverh #2
Can we assume that it is stuck in the down position? Does the position lever move and does the 3pt operate off of it?
The larger position lever labeled 1-2-3-4-5-6-7-8-9-10 does operate the 3-point arms up and down, but the lever to the rear labeled draft and position is stuck forward or in "draft". It is difficult to get the 3-point arms to stop in the middle of their range, it mostly wants to be all the up or down.
/ Ford 6700 draft leverh #4
I will look into the service book, but I'm thinking that internal linkage is broken.
Does it have Load Monitor? You can tell by the presence of a large, long spring on the 3 point hitch.
