Scott Y
HI, I have a Ford 6610 with a cab, there is no loader on tractor, when I purchased it did not have the remote outlets hooked up, I added them, to use I have to pull out a knob on RH side under seat down by floor, this disables the 3 point, this system does not work the best, I would like to add at least one set or maybe two, Broken tractor has a two spool kit for a grand, not sure if this is the best route or not, I am open to adding a separate pump if that makes sense, but would then like to stay outside of the closed center valve situation, I could add a side pump, or there is a place to add a front pump on tractor, this tractor was purchased by the Government (Air Force) as a run way sweeper, this 6610 was made in England. Do not want to spend allot of cash on this, even the grand figure is getting a bit pricey at the current time. This tractor has the CCLS system, (closed center load sensing) Thanks for any help on this!
