Ford 6610 hydraulic oil level
   / Ford 6610 hydraulic oil level #1
cattoon
N.W. Alabama
Kubota L2800
Can anyone help with where to check hyd level? Also does the trans and rear end share fluids or separate levels for each? My brother in law is using a 6610 that belongs to his friend and he just wants to make sure all the levels are good to go. He is an equipment operator but is stumped about where to check all the levels on it. The tractor hasn't had the level of maintenance that it should have prior to this adventure. Thanks
   / Ford 6610 hydraulic oil level #2
Transmission and rear axle/hydraulics are common sump on this machine. Dipstick should be reached from behind the left hand rear axle housing, close to the center section.
Thank you for the quick reply, have a great evening.
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
