Well, your title is in error. The only tractor that is a Golden Jubilee is the 1953 Ford NAA model. Even the 1954 NAA is just called a Jubilee and not a Golden Jubilee. Small detail, but I thought you might be interested.
With your problem, I'd say you need to check the following:
1. thermostat operating properly
2. water pump operating properly (the vanes in the pump can erode away)
3. radiator core completely clear internally and externally for air flow (This is something that may be best checked by a professional radiator shop to ensure each core tube is clear.)
4. restriction in hoses
5. in need of a good flush to remove scale inside the engine
6. fan belt slipping
7. damaged fan or fan shroud
One or more of those issues may cause a problem. There is of course the possibility that your temperature gage is malfunctioning. Is the tractor boiling over? You might want to invest in a cheap IR non-contact thermometer from Harbor Freight to do a double check of the temp gage.
