I have a Ford 655D Backhoe that will not start. I have clean the fuel tank, replaced the shut-off assembly valve, blown out all fuel lines , replaced the fuel bowl, replaced the fuel filter, had the injector pump rebuilt, and removed it a second time to have it checked again to see if is was working properly and the shop that rebuilt it said there was nothing wrong with it and was working properly. When we replaced the injector pump the first time after it was rebuilt the tractor would run for about 60 seconds then shut down. If you waited for about 10-20 seconds it would start back up again and run about the same amount of time. Pull the pump the second time took it back to the rebuild shop and they said it was nothing wrong with it. Now after replacing it the tractor will not run at all without starting fluid . Not sure what I can do next to get this problem resolved. Need help on anything else that might be wrong
