Ford 655c Backhoe Brake Adjustment
/ Ford 655c Backhoe Brake Adjustment #1
hvald1
san bernardino, ca
Ford 4500 TLB
hello people,
i just got a ford 655c backhoe, only problem so far is NO BRAKES.... I need to either adjust or repair... Please anyone have any ideas? Thanks in advance...
Hec
/ Ford 655c Backhoe Brake Adjustment #2
Looks like the same brakes as used on the ag tractors of the era. Look on the front side of each axle housing. You should see the linkage from the pedals connect to threaded rods, one for each brake. Should be and adjustment nut with a jam nut on each. Should take a 11/16 wrench to adjust it.
Thanks Harry in Ky,,,,, I did fine the linkage,,,,,, I plan to adjust!!! Thanks a bunch, much appreciation
