Backhoe Ford 655A power steering
   / Ford 655A power steering #1
Loadstar
Platinum Member
Evansville, IN
Ford 640
-Having trouble finding a good power steering pump filter number.
-I also need to rebuild steering cylinders. If anyone has numbers for a decent kit or know what all parts in a kit I need to look for would be great
-last but not least the ball joints on the end of the cylinder (I believe... going by memory) are done and if I pull cylinders I need to change them also. was wondering if these cross to something on O Riley's shelf they look about the same size as the ones on my superduty.
Any pointers or help would be appreciated. Steering Is sloppy and dumping oil. Seldom used machine being used more than usual so I need to address it.
   / Ford 655A power steering #2
add 10 oz of brake fluid to the power steering it will soften and expand the seals if o ring are cut or broken it should work don`t have to drain it good luck
   / Ford 655A power steering #3
Thank you for the replies. I will have to check the online catalog out.
NEW Fork Extensions (A53002)
NEW Fork...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
